This command disables the dynamic hostname feature.
| area_name | Specifies the name of the IS-IS process for which the dynamic-hostname feature is to be disabled. |
Disabled.
The specified router process no longer includes code 137 TLVs in its LSPs and names are no longer displayed in show commands.
The following command disables the display of area names or SNMP names instead of system IDs:
disable isis area areax dynamic-hostname
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
